How to connect:
MAIN BOARD
Powered by 12V, current is cca 10-15mA
To "Stereo input" is connected computer, mp3player, or anything audio source.
Outputs from bandpass are signed appropriate frequency.This outputs are connected to
"inputs" on VU-meters board.
Resistor R5 is main volume to all filters.
Output level voltage can be trimmed by trimme on output (R13, R21,...), if that was not enough, just put one resistor between filter output and VU-meter board.
Deceleration time of LED column depends on output capacitor (C10,C14,..)
you can modified this time, when you change this capacitor(lower value, shorter time to fade down).
All resistors are on 0,25W.
All capacitors on min. 16V.
VU-meter
Powered by same 12V as main board, current is in peak 750mA.
All device peak current: 7,6A.
